Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 39 of 39
Thread: Encylopedia PS41-380 for all you need to know
  1. #31
    Its always this! SH00T's Avatar
    Sep 2007
    380 Thermostat -
    Aftermarket @ autobarn, bursons and supercheap - 60-80 dollars not held in stock - to order here anyways....
    Mitsubishi Genuine (Made in Japan) under $40.00 it is also slightly different to the one I removed...lighter body, same circumference
    Part # MD350415
    If friendly Forum Advice has saved you Time or Money, Please consider a Donation to keep the Forum Running.
    The Goblin and the 380
  2. #32
    Sep 2007
    Searched for this too many times, for me, and others
    380 Factory Alloy Captured Washer Wheel nuts
    The nut is a NN362C
    and according to this PDF is the same for 380, magna (2nd and all 3rd Gen) and CJ lancer Factory alloy wheels.... @ a wreckers they can also be found on Mirage, nimbus, challenger and outlander in certain years...
    https://www.niceproducts.com.au/catal...Mitsubishi.pdf
  3. #33
    Quote Originally Posted by SH00T View Post
    The nut is a NN362C
    In short nearly all Mits running alloys use the same washer style nut. Later models like lancer and 380 use a domed cap where older models use a square cap. You would be surprised at the amount of sets I have sold
  4. #34
    Sep 2009
    Wiper blades.
    Remember when you buy wiper blade refills, driver's side takes the wider blade (8.5mm), passenger side a narrow refill (6.5mm). Why on earth they did this we will never know.
    I found this out the hard way.
    And the driver's side refill needs to be 24 inchs. 22 inch is a common length but too short.
  5. #35
    Minotaur's Avatar
    Jul 2006
    Quote Originally Posted by steve_bunkle View Post
    Wiper blades.
    Only an issue if you're running stock wiper arms of course... I think it's recommended that the wiper arms get replaced every 5 years or something, so you should be on a new set by now... or buy Aerotwins or something similar instead
  6. #36
    xwhiskey's Avatar
    Mar 2006
    cant find the right thread as i type this, but was cruising the forums over the weekend re phone compatibility with the OEM Parrot BT in the 380's..
    anyway, this week i replaced my aging old nokia and i am happy to report my new Nokia Lumia 920 Windows 8 Phone pairs no worries with the Parrot V3.2 in my 2007 vrx 380.
    If there's a BT - Phone compatibility thread, i guess this needs to go there
    | xwhiskey | 380 | Valet Parking Racing | //// Race Drivers Finish Faster Division ////
  7. #37
    Sep 2007
    Default Kif380's - Replacing faulty 380 ignition switch, a write up and "how to" thread
  8. #38
    Sep 2014
    www.megaupload.com appears to be no more.
    Peter H
  9. #39
    Mitsubishi 380 workshop manual:
    https://depositfiles.com/files/il6lrpg3u
    It is an "ISO file", and somewhat tricky to open/read, if you are unfamiliar with these sort of things- like I am.
    PM me if necessary.
There are currently 2 users browsing this thread. (0 members and 2 guests)
